Flat screwdriver and light hammer....pry them up and bend them out the way. Be easy so you don't snap one off.Never done this before but how do you get the locking tabs off the inner primary bolts? Is there a special way?
You mean bend the tabs back? I'm guessing they are a one time use and need to replace during re-assembly?Flat screwdriver and light hammer....pry them up and bend them out the way. Be easy so you don't snap one off.
Yes I would, but if you don't break the tabs you could reuse them if you are okay with that. Same lock tab you have on your ignition key, I've bent mine out and back a few times.....You mean bend the tabs back? I'm guessing they are a one time use and need to replace during re-assembly?
I reused mine when I had mine off. I'd probably replace them after a the 2nd time they come off, kinda like a paperclip if you keep bending it weakens it.You mean bend the tabs back? I'm guessing they are a one time use and need to replace during re-assembly?
Use lube. Oh boy this should get good.Work it back & forth gently, use lube. Don't force it, it will come off!
Lube the shaft, that way transmission will not clenchIs it possible that I am pulling the shaft out of the transmission? And/or damaging my transmission?
I have done that already, but I am worried that I am just damaging stuff at this point. I got the motor plate to move about 1/16" away from everything, but it does not look like it has moved on the shaft at all. Which makes me wonder if that shaft is pulling out and/or damaging the internals on the transmission.Lube the shaft, that way transmission will not clench
Yes, all bearings are getting replaced.My guess is the bearing is holding it tight. Maybe heat the inner bearing race then tap with mallet? You are replacing it anyway?
I would replace while your are there. Are you talking about the primary drive or final drive ?SUCCESS!!!!!! After 5 hours of loving, caressing, and beating the sh*t out of it, it came off. NOW, I have found that the transmission pulley has a piece of a tooth broken off. It's about 1/4 of one tooth. Should it even concern me? Should I replace the pulley, or just file it so the edges aren't sharp, and proceed?
I've never had one off so I was watching this trend. It was getting really intense there for a while. Glad it worked out for ya. I was beginning to sweat.SUCCESS!!!!!! After 5 hours of loving, caressing, and beating the sh*t out of it, it came off. NOW, I have found that the transmission pulley has a piece of a tooth broken off. It's about 1/4 of one tooth. Should it even concern me? Should I replace the pulley, or just file it so the edges aren't sharp, and proceed?
Front final drive pulley. The pulley against the transmission with the belt that goes to the rear tire. The problem is finding the part number for that pulley.I would replace while your are there. Are you talking about the primary drive or final drive ?
A couple of dings on the motor plate, but nothing worth fretting over. I hope to god I never have to do this again.I've never had one off so I was watching this trend. It was getting really intense there for a while. Glad it worked out for ya. I was beginning to sweat.![]()
Well you had a lot of patience Sir, did you figure out what was holding you up?A couple of dings on the motor plate, but nothing worth fretting over. I hope to god I never have to do this again.
