Please post some pics of the last Knuckle, still my favorite of the Real Harley's. Thumbs Up (- :Been 5 years without liner on BD and over 60 years on my '47 knuckle with no problems so I think you'll be OK.
Had the same problem with My 04 Pitbull. Luckily I work for a chemical company so I could get whatever my heart desired. I found that Methylene Chloride works the best. I am running with no liner with no leaks. I havent had any issues thus far.No octane boost from me- maybe previous owner. Bike has 3,800 miles on it and I've only put 100 of them on myself.
Any of you fellow BD owners running steel without leaks? I have read as many threads on (insert brand here) new liner kits peeling off after a few years as I have threads on (insert brand here) working great. I basically do not want to deal with another peeling liner, ever. Rust is not a concern where I live in Los Angeles, bike is never going to sit empty.
I bought a long pair of grabbers at the hardware store.How do you get the pieces of liner out of the tank?? I have huge pieces in my tank shutting the bike down. I need to get them out ASAP
YES!!! Definitely you should clean the petcock and clean everything through that hole as thorough as you can too!ok. I just bought the grabbers, and got a lot of green chunks out...then vaccumed the rest of with a wet vac. Semms to be free of liner and chunks now..... but im thinking of pulling the petcock and cleaning that filter. Does that sound like a good idea? or should I just run some seafoam through it, and ride ?
Ride a bit with you cap loose and that will tell you if it isnt venting properly or not.another idea I had, ..............take the tank off.....and spray the inside of tank with pressure washer. Fill, shake, empty,,....do it again. I also think I have a venting issue. Bike runs out of gas, only there is some gas left in tank, and I havnt heard it venting in a year. I used to hear the hissing sound of the venting. Now I don't. gas cap is not clogged. I can only assume there is another problem with the fuel delivery system somewhere. carb is clean, fuel lines seem to be clean as well.
Could try a helicoil thread insert.I've had the issue with the old liner start to peel and clog the pitcock; so.........I took it to West End Radiator repair in St. Louis, Mo. and they did get the old liner out, but not without the paint being slightly blemished; which for me is ok since I planned on repainting the tank with newer paint scheme anyway. But now I have a new problem. The threads of the fuel bung are a bit worn down, and I'm told that it would be difficult to cut the old one out and weld a new bung back in, mainly because the inner liner would burn some, and therefore would need to be re lined.....bummer that noise. Soooooooo, now I'm looking at finding a stainless steel hex nipple, with female threads to screw over the old fuel bung outlet, seal it with liquid steel or something similar; and the other end threaded male so I can screw the pit cock collar onto it and have everything back together; Question is: Where can I find something like that? or.......any other ideas that I can consider for a quick solution?
Any information would be greatly appreciated.
I did that one time........ lost that cap on I-35 in Austin TX...... :/Ride a bit with you cap loose and that will tell you if it isnt venting properly or not.
