Brake question - hopefully simple fix
crawfish
I have a brake question for you guys. I just replaced the rear brake pads on my 06 K-9. When I have the bike up on the jack and I rotate the wheel, it causes an intermittent howling noise, like a vibration. What could be causing this? Does it have something to do with the floating rotor? Thanks for the input.
kirk927
Have the pads been broken in? Could be the pads are a little off and need to be broken in to the rotor. Could be a warped rotor also. Did you make sure the caliper is centered on the rotor. It could be a number of things.
Thumper169
I would ride it a little and re-check, sounds like the pads and rotor are not meshing up good, and yes it could be a warped rotor or pistons not releasing freely in the caliper. What kind of pads did you use?
