Bike won't start
DynoDave
If you have a can of starting fluid try a squirt in the carb and see if it fires up. If it does then I'd take off the fuel line and carb and clean both real good.
Thanks, I'll drain the tank and carb, clean the carb, put in fresh fuel and use a little starting fluid.
chubs
Turn of fuel, pull hose off carb, hold ocer catch can and turn fuel back on. Fuel flows? yes, clean out the carb. No, check fuel valve pick-up for obstruction, (Pieces of liner etc.) Check fuel ya caught in can for water or other "crud"
DynoDave
Good idea! Thanks Chubs!
bigkelk9
Yup.. starting fluid is always good answer for a second to verify the quality of your fuel. But spark and fuel.. should run.. so yeah as they all said.. clean her up and shame on you for letting the beast set up.. lok
DynoDave
Making progress....pulled the fuel line off the carb, fuel ran freely into a glass jar. No evidence of water or particulates. Next step; pull, clean and inspect the carb.
DynoDave
I actually fill up with Non-Ethanol here, its a bit more expensive but I deal with it...
I would too but the only non-ethanol gas in this area is 100 LL av gas.
I have used Startron, which is supposed to neutralize the ethanol.
Yep that's what I figured!
Post #26...*cough* lol
