Bike won’t start. Help!!
Stack
Wash my bike got her all cleaned up polished and looking good. But this morning. I walk in the garage and noticed the right turn signal on the Speedo is on. Was not sure why it was on. The bike is off keys are in the house. So I put my keys in the light turn off but nothing turns on no head lights nothing. Anyone know what I should do?
Stack
I unplugged the battery. Made sure plugs are dry put it back together. Same thing. No change. I do notice that EHC is all lite up with no key.
Stack
Why would the EHC lights stay on with with out the key on. I also have the right turn signal light is on as well will no key. I took battery out clean A And B plugs off clean them added dielectric grease. Blown off all pugs with air made sure all plugs and connections are dry. Even took the speedo off and made sure everything was dry. But sill no change when I turn the key I get no power to anything no head light side lights nothing.
Take the key out and blow air in there. You have water in something, that is making continuity to the EHC
Jersey Big Mike
100K mile club
So I'd pull the key switch out of the bike and disconnect it.
You can then jump the wires to simulate the key being turned.
Do you have the MANUAL? See the link on Mr. Wrights post.
Stack
could it be the speedo water did get in there and I blew it out the best I could. Even try unplugging the speedo see if that could be the problem but it still did them same thing with it unplugged
That was my next suggestion. It would just be nice to find out where the water got in so it could be sealed.
Stack
Okay. I unplugged the battery turn the key on then plug the battery back up. Everything came on. Went for a ride around the block to get the bike hot. Runs good turn signal work okay like nothing wrong. Get home and turn it off. And back to the same thing.
chubs
just curious, but what kind of time frame are we talking between washing the bike and now ? maybe try unhooking the battery overnight and like Sven said, blow a fan across the electronics, then give it a try in the morning. You might want to put the battery on a tender overnight also?
First let me say that I do not wash computer bikes just for this reason. I clean most every part with WD40 and wipe it dry. Wetland or ocean climate, I'd clean and let it evaporate. Guy did a car carburetor experiment; one he left it as a clean carb, and sprayed down another carb with WD. Left them in the attic, came back to them a year later, and you should have seen the linkage difference of one rusted up, the WD carb linkage was clean of any rust. That sold me.
I have to look at it as, 'I touched nothing but washed it.' 'I unplugged the power and it lit back up.' 'I took it around the block and got it somewhat warm.' See how you are back to the same thing?
Can't be the battery.
Can't be the black box.
Can't be any jobber on the bike as if heading for a fail mode like a crank sensor.
Can't be what I did last because it runs so it's not previous work done.
Has to be a wet signal still.
How do I verify? I remove the battery ground, let it sit for however long it took you to disconnect/reconnect... and did it fire back up? Computer saved last good signal... and it was a [wet], out of range, saved signal... it should light back up no problem with a clean start signal. Get it?
Everything came on.
As if RAM is the saved out of range signal to start, but you wiped the bad signal by the disconnect so it starts with ROM... or the bike starts clean with 0000 signal. A computer bike starts at zero. See how that makes sense to me in computer speak how it fires back up? No failed jobbers or it wouldn't start.
A crank/cam senor takes more time to heat up the thermal to max heat range and that is all she wrote as far as can't get any hotter. It needed a half day ride with the wind/heat/time. If say you plug the battery back up, take the longer ride or fan it for hours on end. Bring the battery tool if you chase for gas and have to turn it off.
And I'd be chasing my ass to understand why the winker goes hot? As if a drop of water contacts a constant hot pin and the winker pin is next to it? If I owned this bike, I'd know if it has a learn and bleeds off the battery and can shut off 15 minutes later like a car does. Bueller?
As far as I can tell, I doubt if there is any harm spraying WD on the pins on the the main harness side. However, I would not spray the black box's pins. The weatherpac type connectors are used just so nothing liquid enters. I have two options:
1. I can pull the main connectors off the black box, fan it so the pins dry out and just that moving wind around the bike is going to dry more things.
2. Do the disconnect/reconnect at the battery and if it runs, give it a good crank sensor kind of time on it. Think 15 minutes, but more 15 out and 15 back from home is a half hour of hot wind on the parts. Let it sit and cool down. See if it starts. Remember the 'can't be's' if it keeps starting.
Stack
Fan on all night, battery on a tender. Still same problem. Could it be my key switch? If I disconnect the battery. Put the key in and turn it to the on position. Then hook the battery back up. Everything seem to work ok. Bike starts lights com on. But the minute I turn the bike off. It goes back to not working.
