elctronic problems,,,looking for help/advice. I have a 2004 bdm, 107cu.in. I have 0 power going to the controls on either side of the handle bars. Ignition key lights up the speedo and the speedo moves and returns as allways. No power on the run switch, start, blinkers, etc. Fuse is good, battery new, starter rebuilt, all grounds attatched. I have disconnected the battery and ehc and hoped for a reset but no luck. It started today and several times restarted, but again it has failed and I am dead in the water. Any suggestions?? Thanks in advance for your help and thoughts... Gerry
