Belt tension
cdogg556
There's a gauge used to set the tension .at 10 pounds of force, one way, you should reach the 1/4" mark . some run theirs a little less tight for bearing wear. does this make sense.
Yes, that makes sense, thanks Paul for the explanation, 10 lbs of force I understand, I though he was saying for every 10 lbs of weight on the bike, I do run mine a bit looser than the 1/4 to 5/16 measurement, I am right around 3/8"
rschubel1957
Yes that's what I'm saying..the caliper goes over the rotor and the pully that's why the wheel needs to come off to get to the pads
