gascoineted14
I got a 2003 bulldog with a 107 ci has anyone had an issue with the negative side of the battery melting down on start up? The battery was only 1 year old and this is the second time in two years any thoughts? :bang:
Most likely your battery terminal was loose if the starter and CR's are good. Inside the lead terminal there is a metal insert that the battery bolt is threaded into. When the connection gets loose the bolt and insert heats up and melts the outer lead. You can tighten up the bolt more than you wold think, because you are really going into steel with the bolt rather than lead. But keep in mind it is still a very small bolt. :up:
