Bad battery?
Tdubb
Today I went to take the bike for a ride. I turned the key on and the only response I got was the hazards flashing. I have the battery on a tender and it indicates a full charge. I rode the bike on Monday and no issues.
I sure hope its a battery. I plan on taking it out and taking it to the Harley dealership and having it tested. Is the flashing hazards a symptom of a bad battery?
Iman
yes, same thing happened to me - Even though my tender said fully charged - the battery was gone - How old is the battery?
Tdubb
Not sure of the age. Bought the bike a year ago and it came w the battery. It has a drag specialties 310 cranking amp battery.
Tdubb
When I initially had the problem and checked the battery for loose connections the positive was a little loose. So I tightened it up. Same issue - just hazard lights when I turned the key on.
Well my battery is fine. I had it load tested at the Harley dealership and it tested okay. When I returned from the Harley dealership I put the battery back in and turned on the key - all is fine.
Question - is there some type of reset with the ECU? I had the battery out for a couple days. Is it possible that a loose connection would need you to disconnect totally for some time period to reset some fault?
Tdubb
No one answered my question above. Is there some reset required? It's bothering me that simply tightening my connection didn't solve my problem initially.
I do not believe there is a reset....maybe connection wasn't tight enough before? Possbily just got a better bite on the terminals when you hooked it all back up?
bearman
Tight doesn’t necessarily mean clean, or getting a good connection.
For that you need to check continuity between the wire and the battery terminal (not the bolt).
