Anyone using a heal/toe shifter?
RCAdd1ct
JAFO
I use the Heel-toe shifter on my SG all the time.
When I have my feet on the highway pegs it is faster to hit the heel shifter than to hook a boot under the toe shifter.
Moespeeds
I put a reverse shift drum in my bike. $50 from Baker. Changes your pattern to 1 up 5 down. The problem I have these days is I've got the Yamaha's in the mix and there is no way to change the pattern on them, so it gets confusing when I jump off one bike and on another. Prior to getting my chopper 6 years ago, all my riding time was on the track, so the reverse pattern was all I ever knew.
Chris04Masitff
thanks for info Moe.. :2thumbs:
LukeDM
Thanks for the photo. It looks great and is exactly what I was picturing in my head. Who makes that setup?
No prob bro. :whoop:
In his post he said that he made it. Your best bet would be to send him a PM. Looking at his posts, he makes about a post a week or so. If you PM him, be patient, it looks like he'll answer you. His last post was the 18th of January, to give you a time frame. I wish you luck. :up:
DRBarnhart
Insert title here...
In his post he said that he made it. Your best bet would be to send him a PM. Looking at his posts, he makes about a post a week or so. If you PM'd him, be patient, it looks like he'll answer you. His last post was the 18th of January, to give you a time frame.
I sent leandean99 a PM telling him about this post and asking for more info a couple of days ago. But, like you said, he's only on every once in a while...
Maybe another PM will give him a little more motivation? :D
Dennis
LukeDM
Dennis
:lol: It certainly could! Whatever he did, it looks pretty close to factory! :D
leandean99
heel toe shifter
i had pics of it on here before in the gallery but i believe they got deleted when the gallery was updated.
im using a comp at work now, ill post some pics asap.
the mechanic at big dog gave me an extra shifter, i cut the bar off and welded it on the opposite side for the heel, i tacked it so i could make adjustments then i welded it where i liked it.
i ordered an extra toe peg. i have a club foot so i cant shift up, thats why i made it.
it works great. the heel peg can be used as a heel stop, your foot want try to slid down while at faster speeds. i drilled holes in them to match my levers, hand and foot pegs. then i had them chromed. someone on here send me a shifter, im going to make a heel rest for the right side, i have an extra clevis and toe peg, im going to weld it to that, it will have a slight angle due to the tail pipes.
i bought the pegs from xoproducts before he passed away. he was good working with, sent me the extra toe pegs and clevis. stay tune for pics
leandean99
i see someone has already posted my pics, my foot doesnt get stuck or nothing, works great. ill be glad to answer any more questions if any.
A buddy of mine has a double toe shifter... inside shifter is down; outside shifter is up
BigDogRick
I had heel/toe shifter on the Vintage Classic for 12 years. Used it all the time. When I switched out the floorboards and extended them forward I set it up again. STill getting used to the new position.
