Pull the clutch assembly apart I’m certain your starter ring gear bolts are sheard off to the clutch basket, that is the only logical explanation.View attachment 62720 Trying to find out if anyone had the same issue as me with the primary sprocket spinning on the clutch basket,when I hit the starter,it engages the clutch sprocket but the primary sprocket just spins making a winding sound,it’s an 04 Bulldog,thnx in advance
I never pulled the clutch off since I owned the bike ,is there a how to ,so I don’t eff anything up,thnxPull the clutch assembly apart I’m certain your starter ring gear bolts are sheard off to the clutch basket, that is the only logical explanation.
Thnx,Greatly appreciatedRemove the chain tensioner nut and loosen chain
Take the front pulley nut off of engine. RH threads.
Take the 4 bolts out of the clutch pressure plate, and remove plate.
You can leave the clutch disks in place, but know they will fall out when you remove the clutch basket.
Remove the clutch hub nut. LH threads.
Slide everything off at once
You also may need a locking device for the hub and I use a good impact wrench to bust it loose.Thnx,Greatly appreciated
A rag works great.Thnx,do I need to use a special pulley ?You also may need a locking device for the hub and I use a good impact wrench to bust it loose.
There are many locking devices available and I have even used rags in between the pulley and chain.
Proper torque and loctite on install.
Negative ,Thnx,do I need to use a special pulley ?
I'll agree with that on the 05 and newer primaries, but on the older ones, with the compensator, on the engine, you do.You do not need to remove the front pulley to get the chain and clutch out.
Thnx,greatly appreciatedCheck this out granted it’s a Harley but you get the idea. It pretty easy to do but it’s also easy to f shit up too
Thnx,greatly appreciatedI'll agree with that on the 05 and newer primaries, but on the older ones, with the compensator, on the engine, you do.
View attachment 62819 Update,bolts sheared right off the sprocket,any suggestions,not sure if I want to fix it or buy a new clutch,possibly Baker,any suggestions would be greatly appreciated
