Hey guys just joined yesterday and hoping to get some advice before I take my 2009 Mastiff in for repair (don't want to be clueless). This past weekend, i rode in Galveston - awesome place where bikers are welcomed everywhere. Anyway, I had a problem with the bike as follows. Stopped for gas. When I tried to start the bike, the speedometer lit up and lights came on, but bike would not crank. I turned the ignition off but the speedometer and lights stayed on even after removing the key from the ignition....very weird. I tried to switch on and off several times but the electrical system appeared to be locked. I disconnected the positive cable to the battery and reconnected back on and the electrical system reset. I was able to start the bike and everything seemed normal except for the headlights that kept switching to high beam on its own. I switched back to low beam only to have the bike switch back to high after a few seconds. The same thing (electrical system lock and switching to high beam) occurred several times during the weekend....not everytime, but did occur 3-4 times. Any ideas? Could it be the EHC gone bad?
Appreciate any help or advice you may have
