Air Ride
BulletBob
Thank you bdm and woodbutcher. I'm a lightweight in the saddle and would prefer a soft ride. :) I noticed that my PSI goes down pretty fast if I have it up closer to 200...about 10 PSI per 15 minutes. Is that normal?
pknowles
RETIRED
"I'm a lightweight" 200 psi seems a bit much especially for a light weight. I'm a buck 85 and run around 80 psi on my K9.
you need to air it up and spray all the connections with windex and watch for the stream of bubbles. then, repair accordingly.
bdm7250
No, not normal to loose any pressure, I set my pressure and it stays until I air it down. You have a leak ..
BulletBob
Thanks all. Any recommendations on a shop near Austin, TX who can help? I just don't have the time to work on the bike myself except for minor things.
Brent Herridge
Sorry to say Bob - I have used 2 shops and cannot recommend either one. Both ended up doing me wrong, so I'm doing my own work for now. Lorenzo is a member who is fairly active here on the forum, but his shop is in Coperas Cove. Only a couple hours from Austin, but not exactly next door either. You're only 4 posts away from the 25 minimum for Private Messaging (PM). I'll PM you my phone and we can get into my history with shops in town if you'd like.
Drdave427
Are ANY of the air ride parts available anywhere ? I haven’t seen anything except HDM has the solenoid available. Maybe why the original owner took the system off ??
PAUL NOBBS
Got fed up with all the hassle and leaks on my 2005 Bulldog it was an effing pain. Ripped it all out DIY and put 2 normal shocks back in. No more issues thank fuck! - just saying it is one Good solution
