Completely depends on weight of rider and your preferences on how hard or soft a ride your looking for, I run between 85 and 95 PSI typically.What is the recommended PSI on the air ride when out on the road?
Thank you bdm and woodbutcher. I'm a lightweight in the saddle and would prefer a soft ride.I noticed that my PSI goes down pretty fast if I have it up closer to 200...about 10 PSI per 15 minutes. Is that normal?
No, not normal to loose any pressure, I set my pressure and it stays until I air it down. You have a leak ..Thank you bdm and woodbutcher. I'm a lightweight in the saddle and would prefer a soft ride.I noticed that my PSI goes down pretty fast if I have it up closer to 200...about 10 PSI per 15 minutes. Is that normal?
Got fed up with all the hassle and leaks on my 2005 Bulldog it was an effing pain. Ripped it all out DIY and put 2 normal shocks back in. No more issues thank fuck! - just saying it is one Good solutionThank you bdm and woodbutcher. I'm a lightweight in the saddle and would prefer a soft ride.I noticed that my PSI goes down pretty fast if I have it up closer to 200...about 10 PSI per 15 minutes. Is that normal?
