KaptinAmerika
Sorry, asleep at the wheel with too much to do.
You put the meter in series between the positive battery and positive starter lug.
Crank the motor.
The voltage should read not less than 1 volt lower than your battery voltage and your battery voltage should be no less than 12.8 before cranking.
Crank the motor.
Curtis don't you mean the negative on the battery to the positive terminal on the starter?
