2006 big dog Mastiff signal light
jovi
Do the rear signal lights unplug or do I have to cut the wires? Also how do you remove the lens? I bought a new housing to replace my dented one from the wreck. Thanks
Jwooky
There is a slot in the bottom of the lens to use a coin or screwdriver to pop it out.
Once you do that you can pull out the LED circuit board and unplug it if needed.
