2004 Ridgeback won't start after battery change
Dr.Love38
Hello all..
My battery went bad with what turned out to be an internal short. It wouldn't pass a load test even though it had the 13 v at idle. I tested it and checked it with it still connected to the bike. I put my 2 amp charger on it for a while even though it had always been connected to the BT Plus.
Anyway I got a new battery and put it in after checking voltage 13.8 and tried to start it. It spun over great but would not start. I checked connections as the battery was the only thing I had messed with.
After doing some more seaching and reading on here I still have some questions.
The scenerio is turn the key on, I think the second lite down on the ECM blinks yellow, the speedo sweeps up a ways and does its thing, the lights are all on and things seem normal.
I press the run switch and the third light down on the ECM lights solid. I can toggle it on and off by pressing the run switch. Still no lite on the Thunderheart.
I hit the start switch and the lite on the Thunderheart starts lighting on and off like its firing.
No other lites on the ECM are on.
I checked for firing on the plug wires with one of those pen checkers and they pulsed exactly like the Thunderheart.
I also took one of them out and did the old ground deal and it was firing.
A couple of things I am not sure about are the lites normal on the ECM and the Thunderheart. I searched on here and had no luck on a pic of the ECM like I have. As far as I can tell it has just one row of lites.
Nothing has been changed on this bike since new as far as electrical except the battery and some lites Strokers installed a couple of years ago. And I have had no trouble with it except it does not get ridden enough with only 1200 miles on it. Running my own business and also owning a Harley has not left much riding time for the Dog or the Harley.
Any suggestions on this problem ?
N8KAM
Well if you are getting a spark at the plug... is it a good spark?? and pull your plugs and chk/replace them... You do have your fuel turned on right. :D
MARV
were your plugs wet after it cranked and no start?
i'd check that you have fuel thru the carb. maybe pull the air filter and get a visual to actually see the fuel at throttle.
Dr.Love38
OK, gimme the dumb ass award for the week. I went out and checked my plugs for wetness and they seemed a little wet but not very wet. So I ran up to the store and got new plugs and put them in and still no start. My wife came out about that time and asked me if I had gas in it. I thought, well you know, so I checked my odometer and it was like 95 miles. I think I have ran it to 110 if I remember right. So I get my lawnmower can and pour about 2 gals in and get ready to fire it off. As soon as I turned the petcock on I heard a gurgle like some air let loose or something. Well it started up and I went to the station and filled up with 91 octane and rode around a while and everything is cool. I had tried to start it on reserve also but that didn't work. I guess I can chalk it up to setting a couple of months and maybe some kind of vapor lock or whatever. I think I was thinking too much about electrical and all after changing the battery.
Thank you guys for your comments on the matter.
Throttle Jockey
Don't Look at my Member!
Be safe and check your reserve on your petcock. There is something I dont like about what you wrote. Make sure youre out on the highway with plenty gas. Turn it over to reserve and make sure it runs a while. 95 is about where I hit reserve.
TJ
RRRUFF
Glad it was simple fix. I had a cousin who had a mini bike and he would ride that thing all the time until it would just quit on him. He was about 10 years old and he would bring it to me for a fix. Well after the second or third time of no gas I decided to help him remember to check the gas first. Well the next time he brought it to me it was out of gas. So I pulled off the plug wire and stuck in an all metal screw driver and told him to hold it and let me know if he felt anything. After three or four events of this checking for fire and finding it only needed gas he realized that it was easier to put gas in it first then bring it to me.
Dr.Love38
TJ
That's a good idea, I will check that out:up:
Bigtrks
And here’s your sign :) just wait when you get to be my age forgetting is the norm lol
