Cjstallings
Hello everyone.
My name is Josh and I am active duty Air Force stationed in Montgomery, AL. I don't know anyone around here I trust with bikes so I really appreciate everything I have been able to learn and read on this site.
I recently bought a 2004 bulldog that wasn't running. The guy said the ehc was fried after jump starting it.
I ordered the Wire Plus Kit and started installing it yesterday. I followed the instructions as well as I could and used all of the resources I could find on this site. I now have all of the connections made and the switch is hooked up. I tested all of the wires I could as I was installing the unit.
Now when I turn the key, the acc notch gives me the ignition and accessory lights on the power module. I also get the lights around the tach, but nothing on the speedometer or odometer. The on notch gives me lights and the lights or third light on the power module.
I don't get any lights on the compression release, start input, or start output. The light on the switch control module does not come on and the ground is connected to the negative terminal of the battery.
Nothing happens when I touch any of the buttons on the handle bars.
Also, my bike has twin-tech ignition, and I believe it came with the thunderheart?
Any help anyone could give would be appreciated. Thanks for your time.
Josh
Josh
