07 K9 clutch replacment
Sokogsxr6
I just spoke to the company that supplied me the clutch cable. Apparently mine has the hex head nuts on them, Barnett sells a cable that doesn't have those so it slide thru the holders as where mine will not. Looks like I'm grinding the taps off and installing the older version cable clamps. They said the Barnett cable is much more expensive. The one I purchase was $65.
Sokogsxr6
This is the old clutch cable you look closely to the adjustment portion that has been remove from it you can tell its more slender then the one I received.
