pauldeepsea
Never seen anything like this ?Paul, your talking about the square little box with the button to reset?
I was thinking that because the horn came loose it grounded the bike out and caused the breaker to trip or fuse to blow.
I am almost wondering if it may have hit the ignition plate , not sure where they are installed on the 06’s on my 04 it’s rigjt above the horn , mounted to the frameGot ya. I think he said he has the fuse.
Does your bike have the thunder heart ignition with the red led light ? Does the light come on when the key is turned on ?Hit the horn button on my 06 pittbull and the engine died, lost all lightning, wouldn’t do anything. Got it back home on a trailer, pulled the battery out and everything looked good. Hook the battery back up and now I have a neutral light turn signals and oil warning lights even if the key is off. It will turn over but will not start. Any help?
I think he said he checked the fuse already, may want to look at it again ???I have a PDM kit installed on my 06 k9 and if you hit the horn while it is running it will kill the bike. Bigdog sent me a relay kit that was supposed to solve the problem. I've never installed the relay, still sitting in the envelope it came in. But with mine the bike would restart. It's easy enough to look and see if he has the PDM installed, if he does...check the fuse first.
It will if you have a PDM kit. It was ONE of the flaws when the PDM came out, BDM sent out a relay to solve the problemSo the horn button becomes a kill switch?
