jsburkey21
so i have an update; Completely re-wired the bike and the same issue.... dug into it deeper and found the handlebar switches were not working. Ordered a set of handlebar switches and now everything works as it should, however, now this POS wont start! I called Wild Steel Works and he walked us through a couple possible issues and wound up selling me a crank sensor. Got the new sensor Next Day Aired. Plugged it in, still nothing... We tested both the old and new crank sensor by using a multimeter set to AC voltage. Turned the bike over, Nothing on either. We plugged the sensor back into the wiring harness and tried it again but this time back probing the connector. NOTHING. Thinking we just might not be seeing the AC voltage on the Multimeter we used an Oscilloscope, NOTHING. Called back to Wild Steel Works and got an odd reply from him. He said that the crank sensor he sold us was tested before it left and that the "magnet probably fell off the crank". Im not the best with electrical but the magnet is in the sensor and the crank should have reliefs in it that collapse the magnetic field and create AC voltage. I have never heard of, or seen a crank trigger system that used a magnet on the crank. Can anyone confirm or deny this? Does anyone have an actual procedure for testing a crank sensor on one of these bikes? AM I SERIOUSLY UNLUCKY ENOUGH TO HAVE A BAD CRANK SENSOR AND A BAD REPLACEMENT? KEEP IN MIND THE BIKE WAS RUNNING, I TURNED THE KEY OFF TO RE-WIRE IT THINKING THE EHC WAS BAD AND IT WAS THE HANDLEBAR BUTTONS THE ENTIRE TIME.....
