Jeff Taylor
What will be the symptoms of of the stock ignition going bad I'm not sure if mines been upgraded or not
There are so many other things you need to rule out first.
When you turn on the key are you getting the red led at the module under the seat?
Do you have the red and yellow LEDs at the top of the ignition module?
If you do are they flickering as you turn the motor over?
If you have a small dial, with numbers on it that can be turned, on the ignition module then it has been upgraded.
We can tell your bike isn't on! HaNot sure if u can tell anything by this pic or notView attachment 32026
Looks like ya have a loose connection on that hot wire! (and wash and wax that battery before Ker sees it!)Not sure if u can tell anything by this pic or notView attachment 32026
It's answer allusion chubsLooks like ya have a loose connection on that hot wire! (and wash and wax that battery before Ker sees it!)![]()
I think the gap you see is the lock washer hiding under the nut, but it could use a little TLCLooks like ya have a loose connection on that hot wire! (and wash and wax that battery before Ker sees it!)![]()
Thats your EHC
We want to see this
That's not a common part that goes bad.Guess I need to get a new one ordered b4 this one leaves me stranded thanks
