05 ridgeback
There are so many other things you need to rule out first.
When you turn on the key are you getting the red led at the module under the seat?
Do you have the red and yellow LEDs at the top of the ignition module?
If you do are they flickering as you turn the motor over?
If you have a small dial, with numbers on it that can be turned, on the ignition module then it has been upgraded.
Jeff Taylor
