05 ridgeback 117ci s&s.. gaskets and seals ?
so i am putting the motor back together (traded for a basket case) and i need to order new gaskets and seals.. i want to nail it the first time. So would i be ordering seals and gaskets for a s&s super sidewinder + with a 4 1/8" and or 4.125" bore?
will be ordering from eBay, only because i could use the good feedback, and i have time to wait a few days.
need oil pump gaskets, crank seal, base gaskets, etc, etc. Also whats that spacer called that the crank seal rides on? i may need a new one since the previous owner gouged it pretty bad trying to remove the seal.
Brew
I'd suggest you contact (Mick) aka Mcgroom. He's gotten me gaskets for my scoots on many occasions... Just saying
V
Also if have the TP rocker boxes you will need a couple of diff. gasket than the S&S. But like mentioned contact McGroom and get it right the first time:2thumbs:
i would prefer to just know what gaskets i need to order based on bore size or engine type instead of being dependent on a specialist.. The rocker boxes Do look like i will need a custom gasket set for them. But the other gaskets and seals appear to be standard s&s stuff..
I will contact mcgroom about the rocker box gaskets.
now, i wouldn't call Mick a specialist. he's more of a "run of the mill" :roll::roll::cheers:
luv ya, Mick. :2thumbs:
He's good people, and he'll help in any way he can. trust him.
