04 mastiff no spark
Badazz
The battery is new less than 2 months old. I ran a wire directly from battery to coil and still no spark.
SCC007
Check the battery, regardless of age some can have bad cells. I have had several brand new (as in at the store) that failed load test. Deka have been the best for me and all my bikes now have one in them.
Start with checking the battery then start working your way toward the coil. Also make sure to check your grounds.
Mikeinjersey
It stays solid
I agree with JBM . The cam sensor is the most likely suspect. I'm not sure if the sensor can be tested without a special ignition tester from Big Dog but someone on this site may have that info. You can visually check for melted wires but you may end up just replacing it without knowing for sure that it is the problem. Good news not expensive!
Be certain to mark and replace it in the same position of the removed sensor.
Badazz
I agree with JBM . The cam sensor is the most likely suspect. I'm not sure if the sensor can be tested without a special ignition tester from Big Dog someone but someone on this site may have that info. You can visually check for melted wires but you may end up just replacing it without knowing for sure that it is the problem. Good news not expensive!
Ok I will give that a try then. where is that located and how hard to replace
Mikeinjersey
No it's not difficult. This is a link I found on our Technical How To forum
Again!!! Be certain to mark and replace it in the same position as the removed sensor. Also disconnect your battery before doing this job and put the bike in neutral so it can't crank the engine by mistake if for some reason the bike moves.
Badazz
Thank you I will give that a try.
Badazz
I'm sure that's what it is. I carry an extra one with me. Like the old Harleys, you had to carry an extra set of points around with you. HDM does carry a solid state unit that fits in the nose cone, but the cam sensor will fix your problem.
I ha e the old one out now is there a way to test it
There is, and the procedure is in the manual. But it's only about 75% accurate. I've had many that have tested good that were clearly bad. I am a repair shop, so I see a few of them come through here.
