Chopper Goodlett
How much was that?After many hours and many day of trouble shooting this is what I have now. With a 30 amp inline fuse.
Sorry Nascar was on. 12 volt on pin 18 is great I wouldn't worry about 8 volts on 17.Withe the harness unplugged and the key on I only get power on pins 17 and 18 8v on 17 and 12 on 18
Ok so brake / turn single work. No running lights. So that has to be the hot wire output from Ehc or bad connection at main plug. If you take apart one of the connectors from the old harness, and get two females with a short wire attached. Then you could apply 12 volts to each running light to confirm they work. I believe they will. That would test all wiring. It's sounding like the Ehc. Probably not outputting for tach, speedo & running lights? Have fun.Well last night she finally started and ran and I was able to take her out and ride about 10 miles to go fill it up. I shut it off and started it with no problems all night after it started once. Still no running lights, tach, or speedometer. Blinkers and brake lights work and the blinker indicator on the guage does work when I turn eitherblinker on. That’s as far as I got last night. Tool positive wires off battery and but it on trickle charge. Will look at it more today after work.
