Moespeeds
Have you checked to see if you have power going into the key switch? This could only really be 2 things, bad key switch, or bad EHC. Battery checks out good and circuit breaker is not tripped. Have you removed the coil cover, pulled out the key switch, and really checked out those wires under there? The key switch wires are just tiny little things and there is a connector under there. Check all that over.
