02 Prosport drain plug
BuddyRevell
Up here in the northwest the riding season pretty much has started or damn near. I need to drain the oil on the 02 pro sport(never done prior) > I snapped a pic today when I was looking under it from the right side, and not sure which one is oil. I circled with different colors to better help identify. Your feedback is appreciated
BuddyRevell
Few more questions. When adding oil, I read on some old thread with another 02 pro sport on here mentioning about the weld on the oil tank should be the marker being 1 1/2 inches below roughly. Would that being recommended in my case as well? Also, when I started the bike after letting it sit for winter, oil came out of the drain hose. I am thinking that something do to pressure?
The bike will hold 3 qts. Oil coming out the vent tube after it has set for a long time is normal. What happens is, the oil draining into the engine, ( called sumping), can't be pumped back to the tank fast enough, and the pressure from the pistons pushes out the vent. If you start it at least once a month during winter, this will help with that.
BuddyRevell
Thanks for answering my questions again. I'll fire her up once a month this next winter, and add 3 qts when I do my change.
