Carb jetting advance please?
Ivica88
Hallo everyone..I'm a new owner of big dog pitbull 2006 with super G carb and I'm so happy about that..Any sugestion for carb jetting size? running short drug pipe and aftermarket spike air filter..I open the carb and find Intermediate jet 0.0295 and main 0.074...give me some advice what is the best for it???
Ivica88
One more thing I noticed yesterday and make me confused.. I fired up normally, short trip 10km and turned off.. After 5 minutes I try to start the engine but click click click... Battery too low about 11.60V?? Charging system failure, reley or battery?? I'm new owner of big dog so please give me some directions
dtmmil
Get a handful of spark plugs, go do some plug chops, cut plugs apart and see where you are for jetting, make sure you hit the ranges you are trying to jet for.
Jersey Big Mike
100K mile club
If you are only at 11.6 after riding, you likely have a charging system or battery issue.
Charge the battery up at home.
Fully charged battery will be 12.8v
start bike
voltage should be 13V+, rev engine up to about 2000-3000 rpm and voltage should max out at 14.4v
if voltage does not increase or meet these levels its likely your charging system.
If it get that level but the battery still reads below 12.8v, you likely need a new battery.
Many threads on here will tell you to buy a Deka and I can't argue with that -- stay away from cheap no name batteries that make outlandish cca claims.
Ivica88
start bike
Thank you brother for advice.. I will try this today and see what will happen
john sachs
You may find that you need to go down on the main jet, as that air cleaner DOESN'T flow a lot of air. Also, I would put a set of lollypops in the pipes, if there's NO baffles in them . They will help to bring the torque up with those pipes.
John
