Rbriggs197
Still having issues with shutting down. Bike starts with no issues. Take it for a spin and after 5 or ten min. I notice minor misfire. When I decelerate I see emerg. Flasher and it stalls. All lights shut off. I quickly place in neutral turn key off and back on and starts up. The more I ride it the worse it gets until I let it rest over night and then it will run longer but does it all over again until it won't go 1/4 mile. I pulled the tank and did visual of harness. I checked for loose coil wires. Battery reads 12.9 with switch off 12.3 with switch on and 14.5 while running. Hand controls seem to operating correctly. Battery leads are tight and applied dielectric grease to connectors going to EHC. Ignition key seems firm while turning. What I have noticed you ride bike steady and then decelerate that's seems to trigger flashers and stall. I have the rip Gen 2 on order and plan on installing that if it ever gets here. Seems to her worse when it warms up . Any help would be appreciated. One more thing..what about ignition module failing.
