Rear LED lights 2006 pitbull
awg
Oh. They’re not stock? I had no idea.
Yea the pipes, air cleaner, and grips are all after market. Can't see the foot pegs. Someone wanted to personalize it. Not a bad thing just not stock.
Your stock one won't have both wires. Tie a string to the eyelet you take off the circuit breaker. This is the easiest way to get the new wires in
TYPE-II
So when I decide to pull the trigger on getting the OEM kit for this, it should be fairly easy correct? I believe I’ll have to remove my rear fender like someone suggested before, but will I have to remove the tank to do the front? The ones I have on it now look cool, but I’m more of a function over flash kind of person. Plus I like what you said the other day about having the bigger lights makes it safer for others to see what’s going on.
You shouldn't have to pull the tank for any reason. The wires for the voltage regulator run along the bottom of the frame
