BDM CONTROLER TO THUNDER HEART CONTROLER
Has anyone used a Thunder Heart controller or Wire Plus controller in place of a gone bad BDM controller?
Any advise. Can not see spending $780 on BDM controller.
Wires Plus is Long gone. Good options available as Mike suggested. Cool aint cheap.
knothead
You will probably have to call Curtis at wildsteedworx and see when the axels ehc when be back in stock because i know there hasnt been any in stock now for a few weeks as far as 04 and 05 models...think he has a couple 03 versions in stock but thats it
Mikeinjersey
Hey Mike, Do you know if the BDM controler you rfered to in your post is the latest version from BDM.. I know they
The best person to answer that question would be Curtis as Knothead suggested. I believe Curtis also can test your current EHC to make sure it is toast before you purchase a new one.
If youR EHC went bad, more than likely one of two things happened. One, your voltage regulator went bad, or two, your battery shorted out. Or both. You will be money ahead, to change out your charging system, and install a Deka battery. ETX20L 310cca. You can get it on Amazon. Charging system and EHC, www.wildsteedworx.com
I think I hurt the EHC by using a 10 amp battery charger on it. I knew better but did it anyway and I think I'm paying the price now. I did not have the problem until after the charging incident. Has anyone used the Elektronik EHC?
ELEKTRONIK SPECIALTY COMPONENTS
Got one in the 04 Pitbull. Love it.
Most of us are running that unit. There are others on the market, but this one has the best warranty. I'm a BD repair shop, and install many of these units
Mickmorris
Well Known Member
What year BigDog are you talking about? Obviously pre ‘04. I think you can still get replacement thunderheart modules.
Jwooky
The thunderheart is the module used in the BDM RIP and Dead one ESC kits.
You can in fact wire it in yourself, but it’s a lot more work, and you need a lot of electrical knowledge.
This is how I did mine.
