8ball
clutch getting a bit stiff, I switched out quite a while back to a Rivera Primo and it has worked great for a long time. Started being unable to get that easy into 1st shift, after trying many times took apart the ball and ramp side and checked out the works but it all looked good, but of course after I put it back together it was tougher working than when I started. Figured if I'm going back in I might as well change the throw out bearing and switch up to the soft pull if it is applicable to the 2004. Any input will be appreciated
