Garage queen to daily driver
Mickmorris
Well Known Member
Holy stinking guano Batman. Thank you for the huge heads up John. Sorry for calling you Mick, I was a little baffled by all the responses. I don’t know how I missed this issue in my research. Seeing as my bike isn’t even broken in yet it is now parked until I figure this out. Poor rocker alignment and cheap valve guides is a huge red flag for me. Thanks John for having the cojones to bring it up.
Fyi. Some owners with the TP top end have had no issues. It’s like a Monday/Friday thing. Your bike may have been put together on a Wednesday and you won’t have any issues. One of those bummer deals. But that you have a option to fix the problem before it happens is pretty cool.
john sachs
When it happens, it's expensive. You may get a small head start on it, by taking the top rocker cover off, then the rocker arm off :rolleyes:,(pain in the ass), and see that the IMPRINT from the rocker arm roller is hitting the valve stem on center.
John
Jusme
‘05 Chopper RT
For what its worth, Super Start batteries are made by the same company that makes Deka batteries, East Penn mfg. Same volts, same 310cca. You might as well keep the Orielly's battery since you already have it.
Thanks Chubs that’s exactly what the counterman at O’Reilly said. I would like to share with you what I found while testing today. The superstart is 310 CCA battery with unlisted amp hours. after a full charge with my very expensive battery charger it came up to 13 V. After 10 seconds on my load tester it read 12.5 V. The drag specialties battery is rated at 320 CCA and 21.1 amp hours. After sitting in the bike all day It registered 13.3 V. After 10 seconds on the load tester it read 12.8 V. After two minutes it rose to 13.1 V by itself. Seems to me I already have the better battery. And the drag specialties battery was made in Wisconsin 09/21. The super start was made 09/22. If you don’t mind what do you make up all that?
Jusme
‘05 Chopper RT
Thank you for the reply Mick. looks like I have to do an inspection.
Jusme
‘05 Chopper RT
John
Thanks John I did the research you suggested. It absolutely does not sound like fun. But this would be the time to know wouldn’t it?
liferider
Looking forward to retirement
You have had quite the learning curve! Congratulations!! On your front forks. If you start leaking again don’t rebuild them. Call Eric at Derrick and Donna’s. He sells the whole new tubes. Change out is fast. Mr. Wright and Eric helped me at the Gathering 2019 do the swap out. Mr. Wright reworks and rebuilds these machines, he is a boat load of info. Your attitude with the bike is brilliant, keep at it!!!!!
Jusme
‘05 Chopper RT
I have a question for you three wise men. The chopper officially has 3020 miles. If I yank those rocker boxes off do you think there would be enough wear for me to adequately judge the rocker alignment?
makithapn
I plan on doing the front forks this winter if I can gain enough confidence. I’ll be rebuilding the rear brake caliper soon. I polished one side of the front wheel with turtle wax polishing compound and it came out real shiny. I did the rear fender supports with this mothers stuff and came out kind of dull. Someone mentioned the cc purple metal polish. Might try it. View attachment 105881
Wrong mothers you want mothers billet polish
Jusme
‘05 Chopper RT
I want to thank you all for your tremendous help with my wannabe daily driver. Printing up the shop manual was a big help because obviously I had a lot of regular maintenance to catch up on. I rebuilt the brake cylinders, siliconed the connections, bought $200 worth of polishes and preservatives and 3 yards of cotton flannel (that works great). Things are coming along well. I mentioned before the EHC had been replaced in 2010. I noticed it wasn’t working as the shop manual said it should (starter switch mostly). I noticed recently that the headlight won’t stay on. Comes on when I start it and goes out after a couple of seconds. So I want to put in a new EHC from WSW. My problem is this thing they installed in 2010 required some splicing. Anyway I think I’m going to have to get a couple of new harnesses maybe the tail lights and the transmission. Here’s some pictures for your perusal. 44B89FCC-9C7E-431B-AEA8-462E9ADB745A.jpegFACB35D7-E014-4314-B21D-A6CD7D4094A7.jpegCDB2DB53-CB7A-4D60-8CCA-553910DD6CB7.jpeg
[/QUOTE]
That last picture with three plugs on pigtails is how the EHC attaches to the harness.
That's not the EHC that is the ignition module from Thunder heart and those 3 connections are correct. What else is in your battery tray, see what someone put in there.
Headlight going out will it turn back on if you use the Hi/Low switch or stay off?
I've also used the batterywarehouse website and they have very Fresh batteries always within just a few months of mfg date. Amazon prices change frequently based on stock. They are now $125 & I see another seller @ $110. https://www.amazon.com/Deka-Power-Sports-ETX20L-Battery/dp/B0026H3CB4
Jusme
‘05 Chopper RT
The high beam comes on and stays on but the low beam won’t come back on till I restart and then goes back off. I’ll try to find the EHC again when I get home. Thank you.
Jersey Big Mike
100K mile club
Is the low beam good? Did you replace it with an LED or HID light? Some early HID's at least didn't draw enough power so the EHC made the mistake of thinking the bulb was out and switched to hi-beam so you weren't without lights.
Jusme
‘05 Chopper RT
I think I found that little bugger. I had no idea the EHC was so small. I also found that the neutral switch wire had been rubbing against the drive belt where it is not double insulated. I should be able to fix that. As far as the headlight goes it looks good through the lens and I decided it was lifetime bulb because I can’t get it out. That was a bad joke. I’ll keep trying. So now I think the picture below is the EHC. The second picture shows all the splices.753AD980-CD47-4C8D-A8B5-AA6B05C75968.jpegView attachment 110762
