Awesome! Thx Knott!Just remove those 4 bolts in the picture like a full turn at a time skipping around as your taking them out ...by doing this it helps not to bend your spring plate....do the same when putting the bolts back on....do not over tighten them....just bottom the bolts out....snugged up and bend the tabs...
Remember the clutch hub nut is left handed threads....install with red loctite and torque to 80 foot pounds
Welcome buddy....if you got any questions just givw me a ring you got my numberAwesome! Thx Knott!
They upped the clutch hub nut to 150 ft lbsJust remove those 4 bolts in the picture like a full turn at a time skipping around as your taking them out ...by doing this it helps not to bend your spring plate....do the same when putting the bolts back on....do not over tighten them....just bottom the bolts out....snugged up and bend the tabs...
I just checked on the Rivera Primo site says 80 lbs as Knothead stated earlier in the thread.They upped the clutch hub nut to 150 ft lbs
Thats on the right side drive that they upped it...left side 80They upped the clutch hub nut to 150 ft lbs
Chong didnt forget nothing i did i promise....he can do it with his eyes closed now
