Welcome from NJ.I need i forward control for the foot brake that would work on a 08 Mutt. I would appreciate any help with this . Thank you and have a Blessed Day.
Yes, very expensive. Hopefully someone else on this site will be able to help you. Several guys build bikes so they may be able to direct you to a salvage site or other options.Mike, Thank you so much for that info. It doesnt look like they has the whole thing. I think i should try and find a used one. They are not cheap. So ,any ideas where to find a used brake front controller for 08 Mut. Have a Blessed Day, thank you aqain. John
Thank you so muchbfor your efforts and helpYes, very expensive. Hopefully someone else on this site will be able to help you. Several guys build bikes so they may be able to direct you to a salvage site or other options.
HDM may have a complete unit https://www.bigdogpartskingpin.com
Thank you . I appreciate youYes, very expensive. Hopefully someone else on this site will be able to help you. Several guys build bikes so they may be able to direct you to a salvage site or other options.
Thank you i will check it outEbay has listings under usedbigdogparts. Eric at HDM Inc could probably give you some advise.
Sent from my SM-A426U using Tapatalk
Carlos,Yes i need the whole assembly. Pedal, peg, and master cylinder. I can get a picture later tonight. Thank you so much for your helpI have parts that are new never used. What is it that you need the Peg for the foot, or the peg for the brake or arm or the whole thing with the rear master cylinder? I have a 2006 Mastiff and have several parts that comprise the forward control. Take a picture and send it to me cvillalon@aol.com and we can go from there.
Carlos![]()
