Intake manifold K9 engine GE01919
mleach72
The "G" in your engine code means it was produced in the 2006 production year (Oct. 1, 2005-Sep. 30, 2006). The "E" means it is a 4 1/8" bore engine. The rest means it was the 1,919th 4 1/8" bore crankcase produced in the 2006 production year.
OlivaRider
what does "X" stand for?
john sachs
What's the difference, does someone know? 410 2528. 410 2609
Most likely the width of the manifold. Re: taller EPA engines (use wider manifolds) vs. shorter normal production engines. Call S&S and they should be able to tell you the width of each, or the application. If I remember, I'll check my manifold collection tomorrow.
John
John
410 is the width, so both are the same. The other number etched may be a casting run number for S&S reference purposes internally is the only thing I can think of.
Jersey Big Mike
100K mile club
Well the other difference that I see is one is raw and the other looks polished (actually one looks cast and the other looks more like billet)
john sachs
The older sand cast S&S manifolds went out with "winged tip shoes". It took a lot of work to clean up the inside, and they cracked easily on the flange bore. The manifolds in the picture are current models.
John
OlivaRider
[CYTAT="John Sachs, post: 963441, członek: 1842"]
Starsze kolektory S&S z odlewu piaskowego wyszły z „skrzydlatymi stopkami”. Wyczyszczenie wnętrza wymagało dużo pracy i łatwo pękały na otworze kołnierza. Kolektory na zdjęciu to aktualne modele.
Jan
[/CYTAT]
Dziękuję za profesjonalną odpowiedź
pknowles
RETIRED
that's why I said raw vs polished -- it hinted of cast to me slightly but I really didn't think it was.
"winged tip shoes" -- I'm not that old!
John
Damn, I still have a pair... wing tips, not manifolds...
