Unless you are troubleshooting the CB itself you only need to put a meter across the battery terminals and it should read (healthy) 12.8 volts and with the engine running 14.2-14.5 but not more.What is the voltage for circuit breaker with key on and in run mode? Anyone know
I will read thru this and see what I can find I have been having issues since the cold weather has hit and only get a click when trying to start. Battery is goodUnless you are troubleshooting the CB itself you only need to put a meter across the battery terminals and it should read (healthy) 12.8 volts and with the engine running 14.2-14.5 but not more.
Dropbox - File Deleted - Simplify your life
www.dropbox.com
Also thank you for the informationI will read thru this and see what I can find I have been having issues since the cold weather has hit and only get a click when trying to start. Battery is good
The click you are hearing is probably the compression releases when you hit start. Put your finger on top of the CRs and you will feel if they are firing. You can pull the green wire off the starter solenoid and read voltage when you hit the start button. It should go to about 12vdc when the button is depressed. If your getting the 12vdc the ehc is getting the signal from the switch and providing the starter solenoid voltage to operate. If the voltage is correct your issue is most likely inside the starter. The wire inside that connects to the green wire likes to break. If the starter is clicking it may just be burnt contacts.Also thank you for the information
Yea I have done that but I’m lacking 12vdc I’m only getting 8.8vdcThe click you are hearing is probably the compression releases when you hit start. Put your finger on top of the CRs and you will feel if they are firing. You can pull the green wire off the starter solenoid and read voltage when you hit the start button. It should go to about 12vdc when the button is depressed. If your getting the 12vdc the ehc is getting the signal from the switch and providing the starter solenoid voltage to operate. If the voltage is correct your issue is most likely inside the starter. The wire inside that connects to the green wire likes to break. If the starter is clicking it may just be burnt contacts.
Measuring green cable away from starter im getting that 8vdc that isThe click you are hearing is probably the compression releases when you hit start. Put your finger on top of the CRs and you will feel if they are firing. You can pull the green wire off the starter solenoid and read voltage when you hit the start button. It should go to about 12vdc when the button is depressed. If your getting the 12vdc the ehc is getting the signal from the switch and providing the starter solenoid voltage to operate. If the voltage is correct your issue is most likely inside the starter. The wire inside that connects to the green wire likes to break. If the starter is clicking it may just be burnt contacts.
Because It’s a new battery and I charged it before trying to diagnose issueHow do you know the battery is good? These bikes need a strong fully charged one, especially in cold weather. Follow what mike said in the previous post. If you have voltage on the green wire at starter. Before taking the starter apart, you can jump the battery with a car battery but leave the car off. Not running. A weak battery could also cause your problem.
I thought battery was the issue as well but nope battery is ruled outBecause It’s a new battery and I charged it before trying to diagnose issue
Your compression releases are in the middle of the top of heads. When you hit start the CR's should fire for 1 second. Test it with the green wire disconnected so you don't inadvertently have an accident and also so you can clearly know where the click is coming from. You can also feel them with your fingers. If one of them is ceased that could cause you an over-current. The blue light indicates a short, open or over-current but maybe during startup that's normal I can't answer that. You may actually have a problem with that but check easy stuff first.Does anyone know where the compression relief is located located, getting a blue light on my ehc but it’s bright then dim.
