You likely could by using an endoscope thru the inspection cover.Not likely, they would be tough to count, but I could be wrong....its happened before.
The ball ramp to make clutch pull easier is for 9. The company that makes one for either is out of stock and not sure when he ia going to make any moreI ask a lot of dumb questions so here goes, why? Why change from 12 to 9 plates? Just courious. Thanks and good luck.
They are out of stock and are not sure when they are going to make any moreBarnes Performance Cycles had a few of those still available about a month ago. Worth checking
Try going directly to Baker.....The ball ramp to make clutch pull easier is for 9. The company that makes one for either is out of stock and not sure when he ia going to make any more
bakerdrivetrain.com
I did. They dont make the easy pull any more. The lady at Baker said it would be same as stockTry going directly to Baker.....
