Michael rogers
How can I get the shaft bearing out on the primary side
Sent from my SM-G998U using Tapatalk
Transmission 08 mastiffTake a picture of which bearing your referring too, the one in the transmission? What year bike?
They are pressed in, need a puller, which works on the ID, so not really possible with the main shaft in place.Transmission 08 mastiff
Worth mentioning they are pressed in but best not to use a shop press on the transmission to press in or out. Should be pressed in manually with ratcheting tools, otherwise you might crack the transmission case. That's a very expensive mistake.They are pressed in, need a puller, which works on the ID, so not really possible with the main shaft in place.
if your bearing are bad, you need to dismantle the entire trans and rebuild.
