Jersey Big Mike
100K mile club
Absolutely VOES is on Carb bikes and replaces mechanical vacuum advance but gives only 2 settings.You read a 40yr old abstract and they say switch and point to the wrong part. Right back then, not the real walk now. This was the short talk and can be seen as; it only works one way is the processor. It has yet to change like an ohmmeter changes, give or take the 1.8yrs comes the obsolete speed tech is, give or take.
Let me go over your abstract.
No, the V is a sensor that can switch a flipflop inside. The abstract said it was to follow the switch inside the processor. So right there you did not grasp the abstract written right out of the book. Explain please.
Ah, I can see your confusion. Ask yourself who goes on and off. Abstract said we wait for the linear sustained analog signal. We as a sensor physically move to a linear electrical value and the on/off occurs at this threshold, and the flipflop removes current from a magnetic hold for one map, and the load map appears when the switching occurs on the motherboard of the processor.
Again, you have no clue who is being pulled up, and who is switching. You are fixated on a switching at a part and the switching is in another part. Follow the purple wire is the next walk is the ding dong, hello, who is there? Bait. I'm looking for switch.
Wrong. That is not how FI works. Here is how I read this short line of abstract.
The spring pushing it back to OFF? In FI, there are no wires hooked up to a spring to tell when to go back OFF. Test question so you more learn than look clueless on the subject.
A spring calls the ON-OFF
An electrical threshold calls the ON or OFF.
Choose correct answer.
Mike says spring. Then throw the processor away. You went mechanical is the guess. Did you check nature's blueprint on that one?
There is no conflicting anything on my end. I am handcuffed to; "it only works one way." Dude, this is open book. I can tell a sensor from a switch. What has changed with the intake vac is, it is now built with silicone crystal material not paper. Same values spec to said application, give or take an ohm.
Seems like you want to keep coming back to this. I'm going to show you that a V is on the FI bikes now. it Never left. It was the start of FI. So you are saying to throw the baby out with the water temp sensor. I am going to work the parts and moves. Tell me if it is not the same part on FI.
Spring: I think the science gets in the way of this one. See how you have the concept of a spring, and did you work someone's law against that? Build a wafer in the sensor. Take a piece of paper and balance it on one of the corners, you hold the direct other side and let the tip rest on the table. The two tips at their horizontal points, place a wire on each end. Wafer wired up. I'm going to grab a Newton law at that spring.
Mike, you're killing me. I've go you on the witness stand with the evidence on everything you said can and will be used against the on you offed. You said spring and I said for every thing you say can and will be going the other way. Spring in the way. At least you took an attempt to build the sensor, I mean switch. Well, my sensor w/wafer does not work like that. I think I spotted a misstep. How long has this been going on? Think changing the plugs might help?
Got it. You had me at spring. That's it. No can work, fella. My analog just beat your beat back the other way LOL. Does a drum roll? Couldn't you think of spring in a drum against the skin? Does E vibrate? Can you imagine the sound or vibration off that crystal? WOW. Because I heard it drop. Tone sound like a spring to deaden what the whole point of the signal is? A vibe if E gets near it?
Pops in the head:
Mike, what's coming out of the speaker when it vibrates like that and the paper on the speaker is whipping back and forth?
1. E vibes the paper.
2. The person's voice.
Mike says the persons voice. Like saying spring. Like saying the on off is in the VOES. Like saying show me a vac sensor that has yet to change what it does from inception.
Mike, how many points have I shown that you have stumbled 3 times on the FI troubleshooting of the parts on the bike.
VOES/MAF/MAS = Linear as a gas gauge needle that does not on off but acts like the VOMM guys. The, hello, I am here at this point. Do what you need to do, you have the signal. I'm full. Here is your signal. I concluded what my job does. Take it away wire.
555 = The guy on the motherboard. The map trigger switching. Here is the switch.
Mike, where is the spring located? YOu mean the switch? That too.
1. VOES
2. 555
Mike said the VOES... w/spring.
Turns page...
MAP/MAF is used on EFI to sense vacuum and provides a RANGE of vacuum advance.
My orignal argument was you refered to a VOES being on an EFI system.
