Convert 5 to 6 speed
429CV23
The wife and I went for a ride with friends yesterday, around 180mi total. The 5spd is good for about 70-75mph, after that she really starts ringing my bells. I've looked at just replacing the 5spd with a 6spd, but have also seen the retrofit 6spd kits. My '00 Bulldog's trans came loaded with Andrew's Gears; how well would a retrofit set of gears hold up?
Other option is either a smaller rear, or larger front pulley; finding a smaller rear to match the wheels would likely be impossible. Hell, I can't even find a nice seat for this thing!
Has anyone done a retrofit 6spd kit?
2000 Bulldog; S&S107", std LHD 5spd
FrankBDPS
That's kind of odd. My bike will easily cruise at 70 to 75 and has more than that in it. I wonder what gears you're sprockets are.
429CV23
It has plenty more in it; I think 75 puts it around 3k rpm, but the vibration beyond that is no good for more than a few miles (unless you enjoy 10min of tinglydick once you stop). :oldhardlaugh:
Mickmorris
Well Known Member
I would think you could get a Ultima 6 Speed to work no problem on that bike. I have a Baker 6 speed on my 2000 Vintage Sport Chopper. I believe originally it had a Andrews 5 speed. You could check with Barnes Performance Cycles he could for sure let you know about the retrofit.
429CV23
Thanks for the flow chart! I'll check some things on there. Tires should be OK, using DynaBeads in both.
Do all Dogs have solid motor mounts?
