how many times around do i turn the accelerator pump spring to set it its the set up at front of carb
thank you guys i put the three parts together without rotating anything to make spring tighterHMAN has the proper procedure marked with the red marks above. Do everything on the list, and fine tune from there.
John
thank you I put the three parts together without rotating anything to make spring tighterSpring is required to keep screw from vibrating and changing setting. Read the red.
