Mikeinjersey
Refine your clutch rod adj. Here are a couple of how to's that will help you.I did the ATF Type F swap and still can't shift into neutral while running. Only way to do it, while running, is to rev up the rpms then it'll shift (but that was the same way with the spectro)
Dropbox
Dropbox
