What kind of engine oil does everyone use?? In the big dog service manual it says RevTec 20/50. Also says DO NOT USE SYNTHETIC OIL. In the ss service manual it says use Mobil 1 20/50 synthetic. What gives???
Great. Thanks.I use Mobile 1 synthetic in all 3 holes. use to use Amsoil but it became harder to find.
Dogs, Harleys, Indians.
I use Mobil 15-50 synthetic in the engine, 1/2 Qt. low, ATF type F in the primary, 85-140 in the trans.
John
I like bikes with BIG JUGS!! HahaI like girls with big boobs.
I use RevTech. Everyone has a preference. RevTech Transmission Lube & Lucas in the primary
Thanks for all the input on this subject. Ride safeWhat kind of engine oil does everyone use?? In the big dog service manual it says RevTec 20/50. Also says DO NOT USE SYNTHETIC OIL. In the ss service manual it says use Mobil 1 20/50 synthetic. What gives???
DonJohn, what do you mean by 1/2 Qt low ? Do you mean 16 oz (1/2 Qt) in the primary instead of 32oz ?Dogs, Harleys, Indians.
John
Not sure what he was referring to, but if your Dog is an 05 and newer, with the DSSC thin primary, 20 ozs of primary fluid is what goes in it.John, what do you mean by 1/2 Qt low ? Do you mean 16 oz (1/2 Qt) in the primary instead of 32oz ?
Thanks for the info Mr. WrightNot sure what he was referring to, but if your Dog is an 05 and newer, with the DSSC thin primary, 20 ozs of primary fluid is what goes in it.
His is talking about half quart low on motor oilJohn, what do you mean by 1/2 Qt low ? Do you mean 16 oz (1/2 Qt) in the primary instead of 32oz ?
Are you sure ? I can't see what purpose that would serve especially in a 3qt system.His is talking about half quart low on motor oil
