Clogged or blocked pathAny ideas what this could be? Bike sputters on dies when its on the regular run fuel valve selection. If I put it on reserve it stays on without dying. Thanks in advance for any help.
all info is much appreciated!I had residue in my top pet cock from the tank liner peeling. Cleaned and relined the the tank. Removed the debris and my problem went away. I had Iron horse cycles in Decatur do the work. Required spinning the tank with drywall screws inside to clean out the old liner and spinning to app,y the sealer. Carswell Dragons Blood gas tank sealer was used so I could see inside. Caswell provides complete instructions. Not sure you need to go this far but thought you would like the info.
Haven’t got to use that line in awhile lol..And there you go!
