My story!
Update...finally got the compression release fixed. Thanks @bdm7250 for lending me your compression release tool! The CR wasn't bad, it had just came loose. Replaced the left side switch housing, new cables from Barnett and experimenting with a new headlight. Now if I could get the trans fixed!
1 B.M.F.
With that headlight and the risers you put on it has a west coast chopper look to it. I love it. You got me thinking about doing my risers. Where did you get the risers, bars, and did you have to swap out grips? Or what exactly did you do?
Welcome from sector 2,
I'd drain the trans oil, check the magnet for shavings off the fork/dogs? Or, showing a metallic oil drain with a lot of sparkles, we'll call this obviously a rebuild by oil contamination alone.
If I wanted to test for a pop-out-of-gear scenario:
a. Back wheel is off the ground and everything is static from here.
b. Hand on the shifter, other hand on the back tire.
c. I'm going to shift the trans as fast as I can so I am acting the toe and letting go. And that's from 1st to top gear, then down to 1st again. That says the pawl adjust is close enough. I have a problem zipping thru or to 3rd... There you go - Said Scenario.
d. Meanwhile, the back wheel is moved up and down, rather than hand spin a 360°.... won't shift as fast.
e. From 1st, I aim for 3rd and stop. (1)-Front wheel is up against the wall [2x4] and here is where I pull the clutch in so as to get some spin on the tire and pop the clutch. I get chatter of say a gear slipping into a few open holes = It's fucked. (2)-That was my first test. Now I need the wall where I'm going to push that wheel with all I've got and either the engine moves or the trans is the weak link and again, chatters out of gear = Tear Down.
Edit:
f. (3)-I could jam a round shaft type screwdriver under the tooth and link of the lower primary chain so that locks the engine from moving, then with two gorilla arms, snap the back wheel up hard so it loads everything and if that's what it takes to chatter the matter, I say no to loading the link to tooth in said manor. Avoid collecting more parts to the list. You know it's the trans, not the clutch, your shifting, the pawl, etc.
Mikeinjersey
@Mikeinjersey I was born in Md and lived in De before joining the Army! When it pops it feels like I am actuating the clutch and releasing repeatedly. It could be a clutch issue, I assumed trans because of info on the net (Bonjour!). Baker said shifter pawl immediately when I contacted them. He replaced the shifter arm, never opened the trans. I adjusted pawl before and after shop, no change.
OK Again I'm not a trans GURU but I'm more inclined to think your clutch is the issue. Shift arm not wobbly anymore and you are not seeing any change after 2-3 pawl adjustments I would take a look under the trans cover and inspect the pillow block for maybe a broken or missing spring on the rear detente. Your drum would have to be drifting to pop out of gear or be forced out by tension from bent forks. Only 3rd is the unusual part of this issue because you would think all gears would be effected.
Your description of clutch, feels like it's actuating (slipping) and releasing (engaging) also weird(only in 3rd) but I think more likely something is getting ready to let loose. Feeling it in your clutch handle could indicate your Throw-out bearing is banging on your clutch push-rod .
@1 B.M.F. Every time. Right after I took those pictures I was riding home and left it in third and it jerked like it has been then downshifted to 2nd! I guess I am going to have to bite the bullet and pull the trans and have it rebuilt. Baker doesn't rebuild anymore, so I was told, so I need to find someone to take on that project.
Mikeinjersey
Give these guys a call.
Contact Info
Barnes Performance Cycles
321 Chaumont Dr
Endwell, NY 13760
607.727.8545
barnesperformancecycles@gmail.com
bdm7250
Lost some weight in her booty! Now if I could get that fender down on the tire. I know...buy a rigid.View attachment 82095View attachment 82096
Air ride will get the fender down. You can also lower the bike with stock shocks and only takes a few minutes. Before i put air ride on my bike I had lowered it 1", ride quality suffered slightly but was not too bad. Picture below is with the air ride lowered.
Mikeinjersey
Took the chopper to Tombstone.
Glad you can still ride it. I found this video and the guy explains what could be happening to your transmission. On the example trans he says it's usually 2nd gear that starts to pop from torque but it's a different trans than yours. Same type of trans though. Watch it starting around 20 minutes in and he will explain how it's likely the dogs starting to wear can cause it to pop out of gear which bends the forks and down the slippery slope until the trans totally fails. I hope this helps you.
