I'm looking at purchasing the Altima 131 fat bastard engine and putting it in my '05 big dog chopper curious if this will fit ?
Okay smart guys
I'm looking for real answers here
I'm looking at a Altima 131 fat bastard. Does anyone here have experience installing this into a '05 big dog chopper frame and mating it to a synchronized left side belt drive and also on what carburetor to put on it
Mickmorris
Well Known Member
Well if you are buying the Ultima Engine, I believe Ultima will cut you a deal on the R1 carb for that engine. Welcome from Florida btw! Hope you find the help you need here!
knothead
It should fit....the ultima 131 is only going to be 1/4 taller motor...117 thats on your bike is a 4 3/8" stroke and the ultima 131 is 4 5/8" stroke.... you may have to fab a top motor mount if your mount doesnt have a slot machined in it so you can adjust the height to mount the coil cover....either way isnt a problem to make....if your motor is still on the frame take a look and see if you can stand another 1/4 taller motor....i believe you will be good
To the carb question all the 131 engines i have looked at come with carb.....ultima r1 carb
Thank you , I see now that it will come with a carb , are the out put shafts the same ? I'm assuming they are
Mickmorris
Well Known Member
I have always liked duals. Just a personal preference. I sure like the ones knothead put on Frankenstein. I just bought some new short shooter drag pipes but thinking of sending them back. They weren’t exactly what I was looking for. Who knows may just put them on to see if they grow on me. I can’t think of any advantage to 2 into 1. C66DDB74-1B9E-4BED-A4BB-7396194BA1C7.jpeg
Drdave427
I have always liked duals. Just a personal preference. I sure like the ones knothead put on Frankenstein. I just bought some new short shooter drag pipes but thinking of sending them back. They weren’t exactly what I was looking for. Who knows may just put them on to see if they grow on me. I can’t think of any advantage to 2 into 1. View attachment 80948
Other than having 1 FAT PIPE — not sure of any performance difference though
Yeah I like duels , that way I can put my finger over the end and make sure the compression is equal on both cylinders. I'm assuming the output shafts are the same to hook to my primary belt drive ?
Mickmorris
Well Known Member
Yes I do believe that to be correct. If you are purchasing directly from Ultima they should be able to confirm that.
48 mm. Mikuni.
John
Thank you , I'm going with the R1 carb it comes with for now. If I have problems I'll go 48 mm Mikuni , I'm looking forward to this 131 swap project
Welcome from NJ
IF that's how you check compression " YOU ARE THE MAN" :oldlaugh: :chopper:
I actually lost part of a ring on my 117 s&s and I could tell it was the back cylinder by less snap on that exhaust pipe and you can smell your fingers and tell if they're both running properly with the mixture
