Does anyone know if this is characteristic of the EHC?
In other words, is there a 'learn' processing going on? Or saving RAM? Or, is there a clock option? Of course yes to keep time, and the others are just a guess to cause a draw. So if it's in need of saving RAM, or say the bbu works like a car radio... lose 12v, you lose your saved settings. That is more or less what RAM is. Looking at it another way, your computer saves all your uploaded photos and videos and that is RAM. If you wipe the drive, better known as reformat the hard drive, you lose your stuff, but say windows you can't wipe, so that is called ROM, or something you can't change; like the radio booting up for the first time after you change the battery.
The latest Triumphs use an outside relay. The back box has a timer inside and within so many cycles, it turns off or the learn is done and shuts off, who knows? So the Triumph learns and that might be for the 02 or a knock sensor, who knows? Does the BD unit have an inside relay for learn?
Don't know if all that shit is intellectual property, or if GM has some abstract in the shop manual that describes learn for the transmission shift to throttle inputs, to who is seat A and seat B when you just hit the button one time for that learned memory is in recall.
