Hello All:
I have a 2000 Vintage Sport. When I returned from a ride, yesterday, I saw that the key had fallen out of the ignition. I was able to purchase a 3-wire replacement switch, locally and installed it, today. When I turn the key, the speedometer performs the initial "sweep" as it did before and everything looks "normal," but I hear a humming noise. This could have been there prior to changing the switch, as I have always started the bike outside, where there was ambient noise, or I had my helmet on. Is this normal? Related to the switch change, when I tested the wiring, the switch position labeled "B" went to the negative side of the battery. The switch position labeled "IG" went to the positive side of the battery. Is this correct? I haven't started the bike, yet. Thank you, in advance, for the help!
